Subject: Shared pages in localized portals
iionescu
15 Oct 2008 7:25 PM
I have a portal with 7 child portals. The 7 child portals represent the localized version of the main portal in 7 other languages. There are a few pages, however, that do not need to be localized and therefore are common to all portals. Is there a simple way to have those pages / contents be displayed in any of the child portals without having to manually duplicate them in each portal?
Example:
mainportal.com -> Portal 0 (English)
mainportal.com/fr -> Child Portal 1 (French)
Any ideas?
Thank you,
Iulian
17 Oct 2008 7:41 AM
Perhaps the easiest way to do this is to syndicate content that you wish to share, and then use an RSS aggregator module in the child portals to capture it.
Forums > DotNetNuke® > DotNetNuke® Questions > Shared pages in localized portals
