Subject: User Import from Excel
sstoos
15 Oct 2008 1:48 PM
I'm working on a website that the client has several 100 members that they want to add as users.  Is there a way to import the members into the users table in dnn database by using sql?  If so, will it mess up any other tables that might be joined to the users table when an user gets added the orignal way.  Please help.  I don't want to manually enter all of the users.
15 Oct 2008 1:58 PM
I have used John Mitchell's script (http://blogs.snapsis.com/PermaLink,guid,c9d3082b-d7b1-4dfb-8c9c-67c0e864964d.aspx) a couple of times. It's easy to use, and easy to figure out how to modify it to fit your needs.
You biggest problem will be to get the data into an xml file correctly
Forums > DotNetNuke® > DotNetNuke® Questions > User Import from Excel
