Subject: URL Question
bmatthews
13 Oct 2008 5:06 PM
Is there a way to make the URLs a little friendly.
What I am looking to do is make a page and access it by typing in http://mysite.com/About/ and the site loads the correct page of http://mysite.com/about.tabid/88/view/Default.aspx. Just as when you load the http://mysite.com/ it loads http://mysite.com/home/tabid/88/Default.aspx.
If I can do this I have a second question, is there a way to hide the whole ~/tabid/88/Default.apx?
13 Oct 2008 5:39 PM
For starters, check the box to use "Friendly URLs" on the Host Settings page in the advanced section.
bmatthews
13 Oct 2008 5:54 PM
I found the friendly url. I got it to work when I type /blog.aspx and it goes to the correct site. Now if I can figure it out for just typing http://mysite.com/blog without the aspx. thats where I am currently hung up at.
14 Oct 2008 9:16 AM
Take a look at the Snapsis Pageblaster module.  That may do what you want.  There is also a URL rewrite from Ifinity.com.au that might be of use, too.
If you use one of these, please let us know how it worked out for you.
