Subject: How to override HTTP Module?
leadnex
11 Oct 2008 9:12 AM
Want to know, how to override HTTP module like my http module should load before DNN's and decide which portal to redirect to? Please help.
17 Oct 2008 7:43 AM
Anyone have any ideas?
17 Oct 2008 9:26 AM
Perhaps try asking in the main dotnetnuke forum, not sure on this one, thanks,
Forums > DotNetNuke® > DotNetNuke® Questions > How to override HTTP Module?
