Subject:  around every module
databanq
10 Oct 2008 2:19 PM
It seems like DNN adds a span-tag around all of my modules, and inside this tag it adds a div tag. This throws errors when I'm validating my HTML.
Is there a way to fix this?
10 Oct 2008 3:20 PM
Are you using containers? I seem to recall this prob occurs if you do not use a container. I use a transparent container for that task. You can see examples in the free skins that are available to download from here: http://www.dnncreative.com/Tutorials/tabid/261/Default.aspx
(scroll to the bottom)
Forums > DotNetNuke® > DotNetNuke® Questions > around every module
