Subject: How to get country and region full name
UmaRam
10 Oct 2008 4:56 AM
I am using DNN List control to fill the country and region dropdownlist
Code to fill the region based the selected country
Dim objRegions As ListEntryInfoCollection
objRegions = objListController.GetListEntryInfoCollection("Region", "Country." + strCountry)
While displaying the values, only "US", "FL" are displayed.
how to get the country and region full name using this keys.
Uma
Forums > DotNetNuke® > DotNetNuke® Questions > How to get country and region full name
