Subject: Custom Module Development
neenu
06 Oct 2008 11:06 PM
I created my own module using DAL,by adding 4 class files in app_code directory, say alistinfo.vb,alistcontroller.vb,dataprovider.vb and sqldataprovider.vb.
And module being created is alist.ascx and alist.ascx.vb. now it gives error in sql.ascx.vb in one of the function called by its dataprovider,say "DataProvider.Instance().ExecuteSQL(txtQuery.Text)"
Function not found.
Can anybody tel wat can be the mistake or where can i get tutorials or any ebook (paid/free) to learn module development using DAL in DotNetNuke.
07 Oct 2008 7:48 AM
I would recommend adefwebserver.com for good information on writing modules.
Without looking over your code, it's difficult to say what you might have done wrong. But, check the tutorials and see what you can find.
neenu
08 Oct 2008 12:21 AM
Thanks for replying.I have read from this site already and followed the same steps,made module coffeeshoplisting.I am attaching the code files herewith,one is under app_code directory and other is under desktopmodules.but on compiling it gives error in sql.ascx.vb in which i didnt do anything. Kindly see and plz solve my problem.
Attachment: 1108212148671.zip
Attachment: 1108212150254.zip
08 Oct 2008 7:15 AM
You might be interested in the DotNetNuke module template that was released as a free download from EngageModules.com. See the blog entry on their home page.
Forums > DotNetNuke® > DotNetNuke® Questions > Custom Module Development
