Subject: Dynamically Add modules
UmaRam
06 Oct 2008 4:17 AM
Hi, Please advice how to add an existing module in a page to another page in the same portal and in between different portals? Thanks
06 Oct 2008 10:32 AM
You can include a module on multiple pages within a portal by selecting "add existing module" on the control panel. You can also select "display on all pages" on a module's settings page.
If you want to include a particular module and its contents across multiple portals, there isn't a built-in way to do this. There may be third party modules, and it may be possible to do this by getting into the database. If you look at Lee's recent tutorials on SQL modifications to tabs and modules, you may get some hints, and I'd also suggest that you look at the database to see how modules get attached to pages and how pages get attached to portals.
Forums > DotNetNuke® > DotNetNuke® Questions > Dynamically Add modules
