Subject: Implementation of FCKeditor in DNN
vikrant_ps
04 Oct 2008 12:50 AM
    Actually as per requirement i want to implemnt fck editor on a particular column of a gird with spell checker or one more i can do that is can i use one linkbutton to active afck editor at that time
or can i hide the tools of fckeditor or use whenever required
plz reply asap i need it very urgenly
Vikrant Singh
10 Oct 2008 9:16 AM
if you need to hide the toolbar buttons, this is possible in the FCK editor based on the security role of the user that is accessing the FCK editor, to find more information on this have a look at this tutorial: FCK Editor Custom Toolbars and Security Roles
Forums > DotNetNuke® > DotNetNuke® Questions > Implementation of FCKeditor in DNN
