Subject: How can I utilize DNN
02 Oct 2008 4:27 AM
hi!
I a fresh graduate looking to develop my career as a web developer
with ASP.NET & C#. How I can use utelize DNN? - abdul
Welcome to the forum, please ask questions through the forum rather than e-mail me direct.
Well, the possibilities are massive - it provides a framework for you to do anything you need for web based or intranet projects!
Let us know if you have a more exact needs for a project, thanks,
Forums > DotNetNuke® > DotNetNuke® Questions > How can I utilize DNN
