Subject: Security when using edit label control
Dvinod
24 Sep 2008 4:42 AM
Hello Today I posted one question How to edit label.  I tried it with edit label control and I am able to edit label.
But
The thing is like that any user who is not registered is also able to edit the label. Can you give some idea about how I can prevent it and omly admin can make the changes
Thanks & Best Regards
Dvinod
Forums > DotNetNuke® > DotNetNuke® Questions > Security when using edit label control
