Subject: solpart menu and friendly url
vdelisi
16 Sep 2008 5:21 PM
hi, i've tried to use friendly url but i noticed that I'm not able to have the friendly url on solpart. thanks vincenzo
Forums > DotNetNuke® > DotNetNuke® Questions > solpart menu and friendly url
