Subject: Query regarding portal url
kaustav_kar
10 Sep 2008 7:11 AM
In my site there are two portals. The default url of www.mydemosite.com and the portals url is www.mydemosite.com/english.  Whenever I add any image in the english portal it shows the image url like this /portals/2/image1.jpg.  I want the url like this www.mydemosite.com/portals/2 instead of www.mydemosite.com/english . Is this possible. I'm asking this because in one module it shows a link like this http://www.mydemosite.com/english/Portals/2/a78f496c-b794-44ce-9adc-b3bdb6c65780.jpg. If I click on the above link it does not open. If I remove the word 'english' from the url (http://www.mydemosite.com/Portals/2/a78f496c-b794-44ce-9adc-b3bdb6c65780.jpg) then it shows the content. As it's a auto generated link so how can I remove the work english.
Please help.
Forums > DotNetNuke® > DotNetNuke® Questions > Query regarding portal url
