Subject: Pathing issues after setting up a domain name
harlowj
07 Sep 2008 9:42 PM
I had a site configured here: http://www.autorotate.com/portal/chl (all works good)
I then decided to add a portal alias to it ( emspilots.ca ) because it was the primary domain.
However, when I did that and access it via the emspilots.ca address, the logo and other skin tokes quit working. If you right click for properties where the logo was supposed to be it says http://portals/chl/phpaichl.gif. It appears that the domain name is not added when accessing it that way.
Any ideas on the issue or resolution?
Forums > DotNetNuke® > DotNetNuke® Questions > Pathing issues after setting up a domain name
