Subject: redirecting registered user to a specific page
saintX
04 Sep 2008 10:05 AM
Is it possible to redirect a user after registration to a specific page? If yes, please tell me how? Thanks
04 Sep 2008 7:14 PM
Go to the User Settings page under Admin. On that page, pull down the menu and click on User Settings. You can select pages for redirect after login, registration, and logout.
saintX
05 Sep 2008 4:35 PM
Hello and thank you for the answer. May you please kindly explain me more specific where to find the User Settings menu? I can't find it under admin menu.
Thanks again
puuri
05 Sep 2008 7:04 PM
I think I found the area that Joe describes by logging in as the Admin user and then from the Admin menu select User Accounts, and then towards the lower right of the resulting page click on the User Accounts link. This will take you to another page which has 3 sections. About half way into the third section should be the redirect pulldowns for you to use to solve this issue. Hope this helps. Thanks for asking the question - I learned yet another new thing about DotNetNuke by following this thread.
06 Sep 2008 4:09 AM
if you are experimenting with users, I would suggest you look at these tutorials:
Forums > DotNetNuke® > DotNetNuke® Questions > redirecting registered user to a specific page
