Subject: Portal Expiration
cmonroe
03 Sep 2008 1:10 PM
Do anyone know of a way to configure DNN to notify admin when portal is about to expire? If this cannot be done, is there a module I can add that will automatically notify the admin that it is time to renew hosting account with at least a 30 day lead time?
Tks in advance.
