Subject: Event Module Scheduler?
mgordon
29 Aug 2008 12:37 PM
I have setup a Calendar of Events module on my page and have added events, no problem.  The main problem is this:  I want people to be able to receive a reminder of our events.  I have placed check marks, in the settings, the two check boxes that say:
Allow Event Reminders
Remind Anonymous
Under the "Reminder Settings" for the module.  The Question mark next to "Allow Event Reminders" say that Event Module Scheduler must be enabled for people tor eceive email.
Looking in my Schedule settings, I see the following:
      DotNetNuke.Modules.Events.EventNotification, DotNetNuke.Modules.Events with a check box enabled and a time of 30 minutes.
So, it appears to me that the schedule is enabled, but there is still no way of receiving a reminder email from the event.
Any ideas?
Mark
Mark Gordon
Webmonkey
mgordon
29 Aug 2008 3:06 PM
Never mind. I found out that you need to enable the Event Reminder in the actual Event that you are adding, you know where you enter the details? There's a plus sign for Reminder settings. That's where you enable it. Duh!
Mark Gordon
Webmonkey
Forums > DotNetNuke® > DotNetNuke® Questions > Event Module Scheduler?
