Subject: Upgrading from 3.3.7 to 4.8.4
joannew
29 Aug 2008 5:32 AM
I've followed the upgrade procedures to upgrade from 3.3.7 to 4.8.4 and received the status report below... just one error with 4.4.0
I've looked in the SqlDataProvider folder and the text log file has no info in it.
Is it okay to ignore this error as my site seems to be functioning as normal?
Many thanks for the great tutorials and suppport btw...
Cheers
Upgrade Status Report
00:00:00.015 - Upgrading to Version: 4.8.4
00:00:02.379 -   Executing Script: 04.00.00.SqlDataProvider
Success
00:00:03.482 -   Executing Script: 04.00.01.SqlDataProvider
Success
00:00:03.750 -   Executing Script: 04.00.02.SqlDataProvider
Success
00:00:03.813 -   Executing Script: 04.00.03.SqlDataProvider
Success
00:00:03.829 -   Executing Script: 04.00.04.SqlDataProvider
Success
00:00:07.469 -   Executing Script: 04.00.05.SqlDataProvider
Success
00:00:07.469 -   Executing Script: 04.00.06.SqlDataProvider
Success
00:00:07.469 -   Executing Script: 04.00.07.SqlDataProvider
Success
00:00:07.484 -   Executing Script: 04.03.00.SqlDataProvider
Success
00:00:07.563 -   Executing Script: 04.03.01.SqlDataProvider
Success
00:00:07.768 -   Executing Script: 04.03.02.SqlDataProvider
Success
00:00:07.910 -   Executing Script: 04.03.03.SqlDataProvider
Success
00:00:08.414 -   Executing Script: 04.03.04.SqlDataProvider
Success
00:00:08.461 -   Executing Script: 04.03.05.SqlDataProvider
Success
00:00:08.808 -   Executing Script: 04.03.06.SqlDataProvider
Success
00:00:09.076 -   Executing Script: 04.03.07.SqlDataProvider
Success
00:00:09.564 -   Executing Script: 04.04.00.SqlDataProvider
Error! (see 04.04.00.log for more information)
00:00:10.904 -   Executing Script: 04.04.01.SqlDataProvider
Success
00:00:10.951 -   Executing Script: 04.05.00.SqlDataProvider
Success
00:00:12.511 -   Executing Script: 04.05.01.SqlDataProvider
Success
00:00:16.072 -   Executing Script: 04.05.02.SqlDataProvider
Success
00:00:31.173 -   Executing Script: 04.05.03.SqlDataProvider
Success
00:00:31.267 -   Executing Script: 04.05.04.SqlDataProvider
Success
00:00:31.361 -   Executing Script: 04.05.05.SqlDataProvider
Success
00:00:31.393 -   Executing Script: 04.06.00.SqlDataProvider
Success
00:00:32.632 -   Executing Script: 04.06.01.SqlDataProvider
Success
00:00:32.632 -   Executing Script: 04.06.02.SqlDataProvider
Success
00:00:32.632 -   Executing Script: 04.07.00.SqlDataProvider
Success
00:00:34.122 -   Executing Script: 04.08.00.SqlDataProvider
Success
00:00:34.295 -   Executing Script: 04.08.01.SqlDataProvider
Success
00:00:34.358 -   Executing Script: 04.08.02.SqlDataProvider
Success
00:00:34.420 -   Executing Script: 04.08.03.SqlDataProvider
Success
00:00:34.420 -   Executing Script: 04.08.04.SqlDataProvider
Success
00:00:34.420 - Performing General Upgrades
00:00:38.264 - Installing Module File Adsense_01.00.01_Install:
Success
00:00:42.766 - Installing Module File HTML_04.08.01_Install:
Success
00:00:44.978 - Installing Module File Links_03.03.07_Install:
Success
00:00:47.535 - Installing Module File MarketShare_01.00.00_Install:
Success
00:00:51.630 - Installing Package File LiveID_01.00.00_Install:
Success
00:00:52.587 - Installing Package File OpenID_01.00.00_Install:
Success
Upgrade Complete
29 Aug 2008 8:04 AM
If everything "seems" to working normally, perhaps you can ignore it. It is possible that the other upgrades fixed the error. But ... I'd still be nervous. Is that log file completely empty?
Hopefully you kept copies of your database and web directory as they were prior to the conversion. If you did, you could install it on a local machine and test the upgrades. You might want to try upgrading to 04.04.00 to see if you can identify the error ...
joannew
29 Aug 2008 9:58 AM
Hi, yes everything seems to be working fine. I get the following when viewing through Host Settings/ 04.04.00
"The log file is empty for the script version specified. This generally indicates that the script ran successfully."
Do you know where I can find dotnetnuke 04.04.00 installation files to download and try again?
Thanks...
puuri
29 Aug 2008 12:00 PM
I think I saw the answer to your last question on another thread real recently. If you go to the 'Legacy Downloads' section on the DotNetNuke Downloads page, it will provide a link to a downloads page on SourceForge. The URL is http://prdownloads.sourceforge.net/dnn. I just ran down the list and it appears they have 4.04 Installer (along with some other files. Hope this helps and Good Luck!
30 Aug 2008 8:41 AM
Yes, that is the place to look.
joannew
01 Sep 2008 3:15 AM
Hi, Thanks for the info, I've looked for dotnetnuke 4.04.00 Install package on SourceForge and carn't see it or any other previous versions... is there any other places to look?
Has anyone come across this error before when upgrading? After googling the error some people have suggested this particular error can be ignored but I don't want to run into problems in the future... (4.4.0 was an early Performance Release)
Thanks alot...
joannew
01 Sep 2008 9:13 AM
Okay, just to let you know...
I've checked /providers/dataproviders/sqldataproviders for log files > 2byte and the 04.04.00.log
The 04.04.00.log contains 'Error: HelpURL'
One of the dotnetnuke project team has told me its safe to ignore this particular issue.
So I'll move on now...
Cheers!
01 Sep 2008 9:15 AM
You probably didn't click the first link on the page. That will take you to this page:
http://sourceforge.net/project/showfiles.php?group_id=77052&package_id=77939
You'll find every version of DotNetNuke there!
joannew
01 Sep 2008 10:04 AM
okay cool, i can see them now, cheers...
Forums > DotNetNuke® > DotNetNuke® Questions > Upgrading from 3.3.7 to 4.8.4
