Subject: Parent Portals and SSL
LucianV
28 Aug 2008 2:10 PM
I need to install and configure on our server several DNN parent portals (different domain names) and they all use SSL.
From what I know, DNN handles the parent portals based on the Host Headers. Nevertheless, when using SSL, IIS diferentiates between domain names only based on the IP address and/or the port number (Microsoft states specifically that Host Headers cannot be used for SSL).
My question is: can a single DNN installation handle multiple DNN parent portals when SSL is required on the portals?
I would like to avoid installing multiple DNN instances if possible at all.
Thank you,
Lucian
Forums > DotNetNuke® > DotNetNuke® Questions > Parent Portals and SSL
