Subject: Duplicate Meta Description and Tag
vdelisi
28 Aug 2008 9:28 AM
analyzing my site with google webmaster tool , I've noticed that I have Duplicate Meta Description and Tag like the following items:
For the Static Page in the Menu
‎/Barche/tabid/81/Default.aspx‎
/tabid/81/default.aspx‎
For the my Dynamic Page (the description and title is different for each single boat)
‎/Default.aspx?TabId=57&boatid=6‎
/tabid/57/default.aspx?boatid=6‎
For the Home Page
‎/Default.aspx
‎/Default.aspx?TabId=36‎
‎/tabid/36/default.aspx‎
How can I avoid? In the Robots....and how?
Vincenzo
P.S. in the actual robots.txt I've
User-agent: Googlebot
Disallow: /*/ctl/
Disallow: /Default.aspx?TabId
Forums > DotNetNuke® > DotNetNuke® Questions > Duplicate Meta Description and Tag
