Subject: Create Bookmarks/Anchor Points/Page TOC
lb313
27 Aug 2008 5:19 AM
I am developing my first DNN site and have been doing some modifications to the skin I am using and have a question.
The site I am building has a lot of information and I have chosen to have rather long pages. The information is broken up into quite a few text modules on a page with various section headings (module titles), (some other module like documents and links are also used). Does anyone know of a module I can purchase or a way to add into the skin a type of index/table of contents at the top of the page that looks at the modules listed on the page and creates the index/anchor links/bookmarks that you click on and the link takes you to the correct location on that page, rather than doing this manually? Would I still need to add anchor points at the start of each module?
Any help suggestions would be greatly appreciated.
Lisha Belbin
27 Aug 2008 8:02 AM
I'm not aware of a module that does that. And, yes, you have to put the links in manually. I've used the "header" for a module as a place to do that.
lb313
29 Aug 2008 1:16 AM
Thank you for your help Joe.
Kind Regards
Lisha Belbin
Forums > DotNetNuke® > DotNetNuke® Questions > Create Bookmarks/Anchor Points/Page TOC
