Subject: Query Regarding search fuctionality
kaustav_kar
27 Aug 2008 4:40 AM
On my site we have the search feature(dnn:search).  Right now when we search, the search is done within that portal.  That works well for the regional pages but is it possible for the front page to search the entire site…all the portals?  I would not want to do that on the regional pages. The site is having 6 portals and a main portal.
Please help.
27 Aug 2008 8:03 AM
kaustav_kar
27 Aug 2008 10:59 PM
28 Aug 2008 2:39 AM
Forums > DotNetNuke® > DotNetNuke® Questions > Query Regarding search fuctionality
