Subject: URL overflow
likito
26 Aug 2008 1:20 AM
I'm using DNN for one of my portal project. In this project I’m using my own skin. That skin contain left menu. Following describes Code.
<table border="0" cellspacing="0" cellpadding="0" style="width: 100%">
<tr>
   <td height="50" valign="top" style="width: 268px">
      <div id="Layer6" class="ToDoList">
         <ul>
               <li><a href="~/tabid/80/Default.aspx">Homea>li>
         ul>
      div>
   td>
tr>
<tr>
      <div id="Layer7" class="MyReports">
         <ul>
            <li><a href="~/tabid/81/Default.aspx">Starta>li>
         ul>
      div>
   td>
tr>
<tr>
         <ul>
            <li><a href="~/tabid/82/Default.aspx">Middlea>li>
         ul>
      div>
   td>
tr>
<tr>
         <ul>
            <li><a href="~/tabid/83/Default.aspx">Enda>li>
         ul>
      div>
   td>
tr>
So when I click on these links, the URL of the web browser is filling as follows.
http://localhost/testportal/~/tabid/80/~/tabid/81/~/tabid/82/~/tabid/82/Default.aspx
after some time it’s redirected to the error page.
Please help me to resolve this problem.
Thank you.
Pubudu
26 Aug 2008 7:37 AM
Well, removing the ~ is the first step. It's not clear to me why the links are run together.
Instead of doing this, though, why aren't you using a menu? Hard coding could be a problem as time goes on and you want to change the site.
