Subject: registration visability
rogerg1967
22 Aug 2008 5:16 PM
I would like to stop items in the user profile management section from being displayed in admin mode. I can turn the fields off when they user logs in to ammend their details but when I login I can still see all the fields. i dont want to delete them I just want to hide them.
regards
Roger
23 Aug 2008 3:12 PM
I don't believe that can be done.
Forums > DotNetNuke® > DotNetNuke® Questions > registration visability
