Subject: Starter Kit/Package Tutorial
obautista
15 Aug 2008 4:32 PM
Is there a tutorial in dnnCreative on installing the Startkit/Package on Vista using SQL Server 2005, VS2008?  Is it safe to assume DNN 4.8.4 will work on VS 2008?
16 Aug 2008 6:29 PM
If you are just installing DotNetNuke to run it, use the Install package. You only need to use Visual Studio to create modules.
For module creation, take a look at adefwebserver.com for all sorts of tutorials, including installation instructions.
18 Aug 2008 6:07 AM
This shows how to use the install package: How to install DotNetNuke to Vista
It is also currently available for free through the free trial button on the subscribe page
Forums > DotNetNuke® > DotNetNuke® Questions > Starter Kit/Package Tutorial
