Subject: Associate user accounts with parent/child relationship
joshuwaj
15 Aug 2008 1:53 PM
I'd like to setup some kind of parent/child association with users.
What I'd like to do is have an admin role that lets it's  users admin any other users relatged to them
To relate them I added a custom field to the profile.
It layout basically like this:
New field is Distributor
New role is Distributor Admins
If a user is a Distributor Admin he can see and modify all other users who have a matching Distributor
Any ideas? Am I on the right track? I'm trying to make sure to do this inline with the DNN methodology and not just get fed up and role my own solution!
I'm not married to my idea so if anyone has any solutions for this that make more sense or are easier I'm all ears.
Thanks in advance!
16 Aug 2008 6:30 PM
I don't believe that DotNetNuke supports this.
Forums > DotNetNuke® > DotNetNuke® Questions > Associate user accounts with parent/child relationship
