Subject: Host menu gone?
wtaylor
27 Jul 2006 9:17 AM
I am  new to DNN and began a site using the wizard. However, the "host" menu is now gone.  All I have is the admin menu.  In my reading, it talks about how important the host menu is.  Do I need it?  Is there a way to get it back?  Should I start over without the wizard?
I'm having to learn DNN in order to help others with it in my job, so I really need to understand it.  I'd appreciate any help!
        Wanda
27 Jul 2006 10:21 AM
Hello Wanda, welcome to the forum: - The host menu does not display if you are logged in as admin. It only displays when you are logged in as host.
When you create a new portal and specify a username and password for the portal, this is for the admin account. - If you log in with your host details for the overall DNN installation you will be able to view all of the portals within your installation and view the Host menu.
Hope this helps,
digitaldoom
21 May 2008 11:55 AM
I had this problem also...
My whole Host account is gone.
When I login with Admin and I view all the User Accounts, the host account is no longer listed. This has happened to me with several installations!
How can I get the Host account back?
vijaymoharle
22 May 2008 10:14 AM
Host is  menu is  available for  Superuser.
When you  install DNN it will ask for  New Admin and  Superuser Username/Password.
Try log on using superuser credentials and you will see Host menu.
Hope that helps
Vijay
22 May 2008 11:08 PM
As Vijay mentioned, you have be logged in as host, or using an account with superuser privileges to see the host menu.
If you are logged in as an administrator, you'll see the Admin menu, but not the Host menu.
Hello,DNN Nav is available with the default install of DotNetNuke and already installed. - Just look...
RE: Congratulations to Lee and the DNN community! by leesykes
Hello,Glad to hear it is useful. I didn't go for the DVD, but went for the net effect magazine, rece...
RE: Register and Login Links by jncraig
The general scheme is that CSS styles are attached to skins.  I believe that it's possible to switc...
RE: User Import from Excel by jncraig
I have used John Mitchell's script (http://blogs.snapsis.com/PermaLink,guid,c9d3082b-d7b1-4dfb-8c9c-...
User Import from Excel by sstoos
I'm working on a website that the client has several 100 members that they want to add as users.  Is...
RE: Menu bar and CSS by wsiwpg
Ok, i have now added some sub pages to the site. Can you please go look at it now.Thanks.
RE: DNN Creative News Feed not Working? by mgordon
In my humble opinion, the latest News Feed Module (version 4.00) is a complete piece of crap.  It ha...
RE: Register and Login Links by Faith
Joe: Two short questions. 1) It is possible to set a css style sheet for a determined user? ...
Hello, Below is a few paragraphs outlining some background, but my question is: Can I take a p...
RE: DNN Creative News Feed not Working? by ollep
  One last bit before bedtime.   With the below section in the “.xsl” I managed to get it down to...
RE: DotNetNuke UK User Group Meeting by leesykes
This meeting is now cancelled due to insufficient numbers, we will try again in the new year
  Hi Again.   Seems like the “News Feed Style Sheet” option is changed to “XSL Transformation? A...
Hi Again.   Now I’m on to the News Feed Module and RSS Feed.   Is the News Feeds 04.00.00 quite ...
RE: Query regarding menu by jncraig
Doing that forces a reload and recompile of your site.
RE: Query regarding menu by ImageSmith
I have had this problem before. A quick fix: retouch the web.config file by opening in notepad, make...
RE: Trying Flash again - in Firefox. by jncraig
Here is how we have done it ... Note that I put in a bunch of spaces to break the tags, so you'll ...
RE: Changing the House Menu?? by ollep
Thanks lee. The configuration for the separate sub-menu-item list, do you show that in a tutorial...
Trying Flash again - in Firefox. by ollep
I still looking for ways of running Flash Movies in Firefox??? The code provided in the DNN Creat...
Thanks Joe! Just tested and it works fine.   Only thing was that I could only save in the portal ...
Congratulations to Lee and the DNN community! by ollep
On Lee’s recommendation I ordered the “Stompernet DVD” and the first issue of “Net Effect” – and che...
