Subject: skins
parag
19 Dec 2005 5:02 AM
i have created one customized skin and put  [USER] tag in that  but when i upload the skin it doesn't show me option register is there any setting for that or i m missing some part of the code
wht i have done is as follows.
<TD width="200" vAlign="top" align="right" nowrap>[USER]&nbsp;&nbsp;[LOGIN]</TD>
above code i have written but it's shows me only user name and not register option when i m not login....
i need that user registeration option on my home page in my customized skin so plz help me in this
19 Dec 2005 6:27 AM
Hello parag,
USER and LOGIN are the correct tags to use. If you want to double check, compare your skin with the default skins that come with DNN.
I think your problem is to do with the settings within DNN itself.
To enable user registration
Try this:
1) Login as Admin
2) Go to the Admin menu / Site Settings
3) Scroll Down to ‘Advanced Settings’ – click on the plus button
4) Under Security Settings and User Registration:
5) Click on the Registration option you require eg. Public
6) Scroll down and click on the Update button
This tutorial goes into further details and covers how to set up the User Registration Options in DotNetNuke
* The definition of a User in DotNetNuke
* Explains the various User Registration options available
* Demonstrates how to setup the User Registration type you require
This is one of the important settings you need to configure in your DotNetNuke® portal
There are further tutorials releated to this in issue 1 of the magazine.
Hope this helps,
