Subject: Media in internet explorer.
crook_sam
12 Aug 2008 4:29 AM
    on my website's home page I have three media modules running on below the other in the right pane. These are displayed perfectly in firefox browser but are cut off when viewing in internet explorer, does anyone no a reason for this and perhaps a solution to fix it?
Thanks a lot,
                       Sam.
13 Aug 2008 6:38 AM
hello,
Have you specified the width and height for the media?
crook_sam
16 Aug 2008 8:26 AM
Hi, thanks for replying,
                                  yes I have specified the height and width but it has made no difference.
Sam.
18 Aug 2008 7:24 AM
I'm not sure, whenever I have come across this problem with video in IE it has been fixed by specifying a width and height.
Do you have a URL to look at?
crook_sam
18 Aug 2008 10:27 AM
The url is  www.nexus-euro.co.uk, and it is the right hand pane that I am concerned with, (if you run in internet explorer and firefox you can see the difference i mean).
Would it help to have the host username and password, if so is there somewhere secure i could send it to. Thanks so much for your help, i really do appreciate it!
Sam
19 Aug 2008 4:09 AM
if you are only adding images to the page, I would simply use the text HTML module and this should get around the problems of IE.
crook_sam
21 Aug 2008 4:47 AM
Thanks for the advice using the html/text module as an alternative has fixed the problem.
               Sam
21 Aug 2008 4:51 AM
great, glad to help, thanks,
Forums > DotNetNuke® > DotNetNuke® Questions > Media in internet explorer.
