Subject: problem with survey modules
UmaRam
11 Aug 2008 1:13 AM
I am using survey modules in my application. While adding options for  question,  I am facing some problem in the validation in the option list box. After adding 3 or more options,  move up and down are not working properly. Also If i select 3rd option to delete only 1st option is getting deleted. This happens only with new question insertion.
Please help me
Uma.
Forums > DotNetNuke® > DotNetNuke® Questions > problem with survey modules
