Subject: domain name change search
rogerg1967
08 Aug 2008 10:00 AM
I have a site which I want to keep the same but change the domain name on. I have duplicated the site to work with the new domain name. I dont want to have to go through each page and find the old name and replace with the new name as there are over 300 pages. Is there any way I can do a search on the database to find and replace the old name and replace with the new? Which tables might I have to search on?
rogerg1967
10 Aug 2008 12:06 PM
I have used the find and replace tutorial for the text / html module and it was fantastic. All the referances were changed without any issues. Is there any way to do this for menu items which use links?
11 Aug 2008 5:41 AM
possibly, it will be a matter of identifying the table where the links are stored and then changing the find and replace procedure to update the table that you have identified.
11 Aug 2008 5:41 AM
ps. - check the Tabs table ;-)
14 Aug 2008 9:30 PM
Also, Engage Software has a free module called F3 that helps you do the search and replace for text files.
Forums > DotNetNuke® > DotNetNuke® Questions > domain name change search
