Subject: Firefox has detected that the server is redirecting the request for this address in a way that will never complete.
Bobbyjosephg
06 Aug 2008 7:26 AM
   I have the following problem
i am using Dnn version 4.7
Please help
Thanks in advance
Bobby
Nuke Master I
Nuke Master I
07 Aug 2008 8:14 AM
Usually, I find that this is related to the portalalias table. Have you recently made some changes?
Forums > DotNetNuke® > DotNetNuke® Questions > Firefox has detected that the server is redirecting the request for this address in a way that will never complete.
Still no luck with this feed. I can get both of these links to render if pasted in Internet Explore...
thanks for posting info,
03.04.00 Thanks Bryan
