Subject: Edit Registration text
eureka
04 Aug 2008 5:05 PM
Hi Lee and Joe
Can you please direct me to the registration page where I can edit this text:
Preferred User Information *Note: Membership to this portal is Public. Once your account information has been submitted, you will be immediately granted access to the portal environment. All fields marked with a red arrow are required.
Lynn
04 Aug 2008 9:51 PM
It should be in the Language Editor ... somewhere ...
Local Resources\admin\Security\App_LocalResources\Register
The field is: PublicMembership.Text
eureka
05 Aug 2008 2:05 AM
Hi Joe
Thanks, I knew you could immediately point me to the exact folder/file, I have been submersed in the Language Editor for ages looking for it.
Lynn
Forums > DotNetNuke® > DotNetNuke® Questions > Edit Registration text
