Subject: Get TimeZone Value
UmaRam
04 Aug 2008 4:25 AM
I am using DNNTimeZoneEditControl to get the time zone of the user. If I get the value of this control, it is returning the value in integer. But I need to get the string value of the time zone and display it in a label control.
Code
 DNNTimeZoneEditControl1.Value = userInfoView.Profile.TimeZone
 lblTimeZone.Text = DNNTimeZoneEditControl1.Value
Please help me.
04 Aug 2008 8:16 AM
I believe that the names of the time zones are stored as a "list" in the Lists database table.
UmaRam
04 Aug 2008 8:39 AM
I have analyzed the List table. Time zone related values are not stored in that table.
Any other way to retreive the Time Zone value
04 Aug 2008 9:09 AM
Well ... that will teach me to not try to answer questions early in the morning and before the caffeine has kicked in!
There is a "Time Zone Editor" located under languages. That allows you to localize the time zone names.
But, I haven't yet figured out how to get the time zone info from this.
carlitossalcedo
01 Oct 2008 5:45 PM
Hi i am using the same control to let the user edit its Timezone but i cannot update the new timezone the user selected, i wondered if someone could tell me how to update this info.
Forums > DotNetNuke® > DotNetNuke® Questions > Get TimeZone Value
