Subject: House Menu and child pages
mtarby
29 Jul 2008 12:37 PM
What do I have to do to get my house menu module to include the second level of pages
Parent Page
    Child 1
       Child 1a
       Child 1b
    Chid 2
Currently, only Child 1 and Child 2 will appear in the menu, I can't get 1a and 1b to be included as a sub menu.   I've tried adding a second instance of housemenu to my skin (one instance is used for a top navigation bar).  That only gives me Child 1a and Child 1b and nothing else.
Then I looked at the HTML that DNN was spitting out and saw that when I tried to add a HouseMenu as a module, it looked like if I tweaked my CSS, it would pick up, but that didn't work either:
#navigation ul ul a{
padding-left: 12px;
background-color: #6699cc;
width: 132px;
_width: 144px;
#navigation li ul{
position: absolute;
left: -9999px;
margin-left: 144px;
_margin-left: 144px;
margin-top: -21px;
z-index: 999;
I'm lost as to where to go from here.
05 Aug 2008 5:42 AM
Have you had a look at:
How to create Horizontal CSS menus in DotNetNuke using the HouseMenu
Forums > DotNetNuke® > DotNetNuke® Questions > House Menu and child pages
