Subject: Error while trying to edit the page settings
ambatisreedhar
29 Jul 2008 11:55 AM
            There is a module called Welcome , which comes in Home page of DNN website.I login to the site as host and In the control panel i selected the option settings(page settings).On click of that option i get a error like this.
Error: Module is currently unavailable.
DotNetNuke.Services.Exceptions.ModuleLoadException: Object reference not set to an instance of an object. ---> System.NullReferenceException: Object reference not set to an instance of an object. at DotNetNuke.Modules.Admin.Modules.ModuleSettingsPage.BindData() at DotNetNuke.Modules.Admin.Modules.ModuleSettingsPage.Page_Load(Object sender, EventArgs e) --- End of inner exception stack trace ---
please help me with your suggestions which will resolve this issue.
Sreedhar.
29 Jul 2008 3:35 PM
Take a look at the site's Event Log to see if there is a more descriptive error message.
Forums > DotNetNuke® > DotNetNuke® Questions > Error while trying to edit the page settings
