Subject: Problem in News Feed RSS module
kaustav_kar
29 Jul 2008 1:05 AM
I've used News Feed RSS module in one of my websites. But it's not showing the results properly. It's only showing the normal text but at the time of displaying image or hyperlink it only shows the html img tag and anchor tag.
The news feed that I provided in the module is
http://web.mac.com/coachgriff/WandV/Jason_D._Griffith/rss.xml
I've used other feeds also and they are being shown properly. You can see the output in the following site http://be30.businessedge30.com/GoogleMap/tabid/77/Default.aspx
Please help.
31 Jul 2008 9:23 PM
I don't have any suggestions other than to note that if other news feeds are displaying correctly, there must be something odd in the one that you report.
Forums > DotNetNuke® > DotNetNuke® Questions > Problem in News Feed RSS module
