Subject: PDF File Content
billkidwell
28 Jul 2008 11:11 AM
I have been using word docs and copy/pasting content to the page or using notepad and suffering the lack of formatting to accomplish the same thing - getting contnet onto pages on my DNN site.
I am told that the best way to add content to a page is to use a pdf file. But, and maybe I am missing something basic, how do you get a pdf file in the edited text area of the page?
28 Jul 2008 6:54 PM
I don't believe that it's better to use PDF documents.
If you are pasting from Word into Text/HTML modules, look for the "paste from Word" button and use it. That will remove Word-specific formatting.
Often, I'll work in an HTML editor to clean up and organize text. Then I copy that and paste into modules using the source option.
