Subject: uploading wmv files to older version 4.0
ellie@enablingtechcorp.com
28 Jul 2008 10:30 AM
Hello,  I'm a nubie at this and have gone in under host and added the ability to upload wmv files. However, when I try to upload it will not complete without and error message or page not displayed.  Is there a file size limit or something I don't know about preventing this? Thanks for any suggestions!
28 Jul 2008 6:55 PM
Yes, there is a file size limit in web.config, and it is probably set to 8 mb. You can change it by editing web.config. Just search for "8192" and you'll probably find the line quickly.
Forums > DotNetNuke® > DotNetNuke® Questions > uploading wmv files to older version 4.0
