Subject: Using 2 Menu in Dotnetnuke Portal
iddgroup
25 Jul 2008 7:43 PM
 i want to know how can i use 2 Menu in dnn , like at the moment i am using SOLPART menu horizontal at the Top and now i want to make different links at the footer of page for adding different links into there.. can anyone help out!!
thanks
26 Jul 2008 9:43 AM
The answer will depend on what you want to display in the second menu.
The menu functions in DotNetNuke use the existing page information to construct the entries in the menus, so you are limited to pages like that.
If you want to display a completely separate set of links in the footer menu, then your best bet will be to put them in manually.
Forums > DotNetNuke® > DotNetNuke® Questions > Using 2 Menu in Dotnetnuke Portal
