Subject: Forgot password
Bobbyjosephg
25 Jul 2008 9:58 AM
   Currently in DNN the forgot password resends the password that was entered by the user.
Is there a way in DNN by which a radomn password is generated and sent to the user so that even the admin does not get the password set by the user so as to increase security.
Thanks in advance
Bobby
31 Jul 2008 9:29 PM
I don't believe that this functionality exists.
But, you can configure DotNetNuke so that it uses passwords that can't be discovered.
