Subject: Dynamic Registration - Viewing Data Fields
billkidwell
23 Jul 2008 6:07 PM
A DNN "guru" set up and "manages" the dynamic registration module for our web site. The registration data capture is customized with a variety of fields, but I am unable to figure out how to view those fields for each user and this is making it very difficult to manage them. Unfortuneatley the site support is not timely when we have quesitons and I need a quick answer about how to see "who completed what" when they registered. Do I need a special module that is outside of the basic DNN that I use? Sorry if none of this makes sense. I am a user not developer.
25 Jul 2008 9:36 AM
If you are logged in as an administrator or host, you can go to the User Accounts page to look up a user. Then click on the edit link and then click on the link to the user's profile properties. You'll see everything on that page.
Forums > DotNetNuke® > DotNetNuke® Questions > Dynamic Registration - Viewing Data Fields
Glad you sorted it, thanks,
