Subject: Grid View loosing CSS
pczurak
23 Jul 2008 12:28 PM
I've created a module and this module has a GridView with AutoFormat, but the problem is when I click to see another page in the GridView I loose all of the CSS formatting.  Does anyone knows what could be causing this or how I can fix this?
Thank You
Peter
Forums > DotNetNuke® > DotNetNuke® Questions > Grid View loosing CSS
RE: style search CSS or XML by mmcinulty
Hi Leei was able to replicate the mouse over affect by using the css, the problem is that i still ha...
Still no luck with this feed. I can get both of these links to render if pasted in Internet Explore...
thanks for posting info,
03.04.00 Thanks Bryan
