Subject: OK, I Upgraded, But Where Did CAPTCHA Go?
mgordon
22 Jul 2008 1:26 PM
Hola All,
I went ahead and made the plunge and upgraded my live site to 4.8.4.  Woo-hoo!  No serious issues.
The only thing I can't get to work again is CAPTCHA for my login.  I went into User Settings and selected the option for "Use CAPTCHA For Login", I cleared the CACHE and Restarted the Application, still, no CAPTCHA form for login.
Ideas?
Mark
22 Jul 2008 5:17 PM
Hi, Mark!
My 04.08.03 site is showing that behavior.  I get the CAPTCHA control on the Registration page when I ask for it, but I don't see it on the login control.
Looking back in the forums (search for "captcha") I see that this has been reported, and for version 4.7, too.
mgordon
22 Jul 2008 9:25 PM
Joe,
I think I've solved the problem.  Under Admin/Authentication, there is an option to enable CAPTCHA as well.  So, two places MUST be checked off on to allow CAPTCHA.  Under User Settings and then under ADMIN/AUTHENTICATION.
Once I did that, I now see CAPTCHA.
Not sure why you can see it on Registration page but not on Login.  Are both settings checked off in your site?
Mark
23 Jul 2008 7:45 AM
I'm glad that you're checking my work! Yes, that's the answer.
I'm also glad that the upgrade to 4.8.4 went well. I hear that there will also be a 4.8.5 before we get to Cambrian ...
mgordon
23 Jul 2008 7:54 AM
I heard that as well.  Maybe even a 4.8.6...time will tell.
Thanks Joe...
Forums > DotNetNuke® > DotNetNuke® Questions > OK, I Upgraded, But Where Did CAPTCHA Go?
RE: Database error by derpir
Hello thanks for the tip Lee but I can't find were to change the Authentication mode on my SQL Serv...
have a look here
This might help you: DotNetNuke.Entities.Users.OnlineUserInfo It's always better to use the busin...
