Subject: Hiding "Register" link from Users
Albatroz2000
21 Jul 2008 3:58 PM
I am trying to hide the "Register" link from my login page.  The site is Public and needs registration but I wish to use my "Purchase Now" button to take the user to the Registration screen.  How would I do that?  I am using version 4.8.4.  I do not want the users to see a Purchase Now button AND a Register button.  Any help is greatly appreciated.
By the way, I think I know how but maybe there is a better way.  Do I just copy the registration page link and use it as a link for my Purchase Now button or is there a better way to push the users to the registration page?
Thank you
22 Jul 2008 7:29 AM
To remove the register link you can remove the [USER] token from your skin.
As you say, you can then copy that link for your purchase now button.
Albatroz2000
23 Jul 2008 10:12 AM
Thanks Lee. I did that and the Register button is not there in the Login module. However the text link "Register" still shows up under the Password field right above the Remember my Password text link. The button is gone but the text link is still visible. How do I take this out?
05 Aug 2008 4:28 AM
You could change the type of registration option available for your portal, go to the admin menu/site settings:
Check out DotNetNuke Users & Setting the Registration Options
You may also want to view this post who has a similar question
Forums > DotNetNuke® > DotNetNuke® Questions > Hiding "Register" link from Users
WOW GOLD by wowgolds987
RE: Pop up window by yerann
RE: Events calendar by mjbieg
