Subject: Subject: DNN menu not showing on IE 7 after changing portal alias
ambatisreedhar
21 Jul 2008 11:00 AM
I upgraded my dnn recently to 4.8.4.
I added a portal alias using the dnn control panel.
After accessing the portal using this alias i find that there is no top/header menu.
Clicking the login or register link also does nothing.
All is fine if I access the portal with the old alias ('localhost')
This problem happens only on IE7 and only on certain machines
I have a few questions:
- Is there a way to change the default portal alias?
- Is the default portal alias ('localhost') hard coded somewhere which is causing this to happen?
21 Jul 2008 3:51 PM
Exactly how did you change the portal alias?
ambatisreedhar
22 Jul 2008 5:25 AM
I tried changing portal alias by adding an alias using the control panel and also by changing the first record in the portal alias table. In both cases the menu does not show up. setting it back to 'localhost' and accessing brings up the menu fine. System Configuration is Windows 2003 service pack 2 with Internet explorer version (IE 7.0.5730.11).
22 Jul 2008 8:16 AM
When you change the portalalias entry, what do you see? Do you see the page without the menu?
ambatisreedhar
23 Jul 2008 6:09 AM
hi,
I was not able to see the Menus .
23 Jul 2008 7:56 AM
I've no ideas. If you want to send me the two URLs to your site, so that I can see what you are seening, send them via email to jncraig at gmail.com.
Forums > DotNetNuke® > DotNetNuke® Questions > Subject: DNN menu not showing on IE 7 after changing portal alias
RE: Pop up window by jncraig
Pop up window by yerann
