Subject: Turn Off Display Container in Template
alexku
17 Jul 2008 12:38 PM
How do I turn off display container in the template? I don't want the container to be displayed for the default modules placed on my pages when they are created with a template.
Thank you.
-Alex
17 Jul 2008 7:31 PM
Probably the easiest way to do this would be to create the template from a site that has container display turned off.
IF you haven't done that and already have a template, you should be able to edit it in each of the module settings in the template. If you don't know the syntax to do this (and I don't have that memorized either), create a new template with container display turned off and check to see how this is reflected in the template file.
Forums > DotNetNuke® > DotNetNuke® Questions > Turn Off Display Container in Template
