Subject: Dotnetnuke Database/login module development
nukedoubt
14 Jul 2008 11:34 AM
I am working with dotnetnuke 4.0.  I need to work with database in dotnetnuke module.  I am creating a module which will display products using web services.  Now i need to integrate a login module(no third party) to the module.  So login need to store on database.  Please give some links for data access using dotnetnuke and login module development.
thanks
14 Jul 2008 8:05 PM
I'd suggest that you study the existing login module.
nukedoubt
15 Jul 2008 3:00 PM
can you help me to provide some links regarding that ?
15 Jul 2008 5:43 PM
Download the source code and look for the login module. It's either in the Authentication or Security directory under Admin. I can't remember.
Forums > DotNetNuke® > DotNetNuke® Questions > Dotnetnuke Database/login module development
