Subject: Unique Text/HTML Module Problem
mgordon
11 Jul 2008 9:44 AM
I went ahead and removed the Google Ananlytics Code from my default.aspx file and instead, created a TEXT/HTML module on my home page in my BottomPane area.  I added the code from Google Analytics there and then check the option to display module on all pages.
Dummy me!  I don't have a BottomPane on all of my skins, so the module is showing up on some pages and not all.  Problem is that I have about 150 pages total and really don't want to go through the option of page by page deleting the module, or, alternatively, figuring out which page doesn't have the BottomPane and then going in and manually adding a TEXT/HTML module somewhere and re-doing the code.
Is there a "Do-Over" button?    A reset?  A "Ooops, I screwed the pooch" button that will allow me to remove what I just did and start over by putting the module in a Pane that all of my skins possess, loike my "LeftPane"?
Please let this dufus know.
Mark Gordon
Webmonkey
mgordon
11 Jul 2008 10:02 AM
Never Mind.  It would appear that DotNetNuke is much more smarter than I.
It went ahead and found a place on the page for the module to appear, even though I don't have the same Pane on each page.
Duh.  I am thoroughly self-chastised.
Mark Gordon
Webmonkey
15 Jul 2008 6:01 AM
If you come across a similar problem in the future, the issues on working with SQL demonstrate how you can apply fixes like this across all of your portal in a matter of seconds, check out:
Cheers,
Forums > DotNetNuke® > DotNetNuke® Questions > Unique Text/HTML Module Problem
