Subject: How to know the number of Registered Users?
kishoreD
11 Jul 2008 4:41 AM
Hi folks,
I am working with Dotnetnuke 04.05.05 version.
I would like to know the numbers of users registered for a specific website. i.e suppose if 100 users registered on my website, we should show with '100'.
Is there any property to get the count?
Kishore
11 Jul 2008 8:31 AM
I'm not aware, but you could do this easily with the Reports module and a database query like: select count(*) from users.
Forums > DotNetNuke® > DotNetNuke® Questions > How to know the number of Registered Users?
